In the process of the automotivedrivingbelt Rubber Timing Belt |
BerniceSparks
Postów: 3
Data rejestracji: 08.03.17 |
| Dodane dnia 08-03-2017 08:18 |
With the emergence of Rubber Timing Belt and airbags, occupants of the safety factor is also greatly improved, but there are still many people do not attach importance to its importance, "knowingly guilty", always have a chances. Of course, there are friends do not know how the Drive belt, Xiaobian finishing the Drive belt of the correct system, take a look at it!
Before the Drive belt, first check the Drive belt situation, slowly hand Drive belts down, the Drive belt should be able to smoothly from the winder pulled out; suddenly pull the Drive belt, should not move. Otherwise, for the Drive belt failure, use the button can be released by pressing the button. In case of damage to the Drive belt should be replaced in a timely manner.
Drive belt method:
1, check the safety of the drive belt, the first adjustment of good sitting position. The distance between the man and the steering wheel with his hands flat hands behind his right hand on the steering wheel is appropriate; legs about 90 degrees bending, so that if the emergency braking, the legs more flexible response, when the crash, but also to ensure Leg enough to buffer, to avoid cross and upper body damage.
2, adjust the Drive belt. Hold the buckle and lock the tongue, slowly pull out the waist belt, to ensure that the shoulder belt from the shoulder, close to the neck, and comfortable and close fit the body. Waist belts below the abdomen, and as low as possible, the same to fit the body. Then, insert the Drive belt clip into the buckle until you hear the sound of the tower.
In the process of the Drive belt, the three-point waist belt Timing Belt Company should be as low as possible, tied to the hip, not tied to the waist; shoulder belt can not be placed under the arm, should be inclined to the chest. Drive belts can only be used by one person, it is forbidden to use; do not use Drive belts to twist. |
