Autor [S] Porsche 924 '83
944Vilnius
Postów: 39
Data rejestracji: 25.09.12
Dodane dnia 19-08-2019 18:38
Hello,
My Porsche for sale. Doesn't need welding. Lithuania, Vilnius.
https://autoplius.lt/skelbimai/porsche-924-2-0-l-kupe-coupe-1983-benzinas-9325119.html
The car is in running order but some things need to be done to bring it back to the road.
Included with the car:
Car service pack (belts, oil, filters, spark plugs, etc.), rear axle, gearbox, torque tube, front brake discs, some other parts in photo. Last photo is what it could be like (you may know that car owner smiley )
Needs to be done:
Speedometer cable is broken (included), cooling fan switch (included), rear axle mount (included), the top of the roof needs repaint (bad preparation but no rust), the gearbox works fine but when the gear is in neutral position the gear shift lever is a little bit shifted to the right (needs linkage adjustment or gearbox repair). Maybe some other misc. stuff which I do not remember at the moment.
I speak English, Lithuanian or Russian. I can arrange a call in a Polish language if required.
Regards,
Martynas
