Autor "To ABS or not to ABS"
Dodane dnia 04-04-2010 21:34
Ponieważ muszę trochę poprawić hamulce w mojej wydmuszce (problemy z balansem) i w związku z tym rozważam różne opcje (zmiana zacisków, ewentualnie dołożenie ABS - leży w garażu), ostatnio trochę doczytuję w temacie.
Znalazłem na rennlist ciekawą wypowiedź użytkownika Cole dotyczącą ABS - może kogoś zainteresuje.
" If you need something to drink I suggest you get up and go get it now, maybe get a small snack too. ABS is a HUGE pet peeve of mine and I am about to write a short book that should be worth the read. Just bare with me for a few.
I have taught performance driving since 1992 from beginers to Indy Car drivers. ABS is one of the most mis-understood concepts ever.
Lets' look at a few basic concepts here first. First you must understand the concept of traction. Imagine for a moment that your car has 100 "units" of available traction. You can use these "units" for any action in the car individually or as a combination.
Example:
-100 units to accelerate with.
-100 units to stop with.
-100 units to turn with.
or some combination there of.
-60 to turn and 40 to brake.
etc.
As soon as you go over the 100 unit mark and try to use 101 units the car will slide. How it slides depends on which direction you were trying to use too many units.
To do ANY action in the car with the most efficiency you must use ALL 100 units for that action ONLY. So to get the most powerful turn out of the car you want to use 100 units to turn with. Which means you can't be applying throttle or brake, it must be constant.
To get the MOST braking power you want to use 100 units to brake with. If you use too many (101) then the car skids. What is also true about using 100 units to brake with is that you no longer have any units to steer with. If you are at maximum braking and turn the steering wheel, the car will continue straight.
It is this action of losing steering control that created "Anti-lock braking" systems. ABS was NEVER intended to stop the car in a shorter distance. What it was designed to do was keep you from using too many units of traction for braking and actually give you some left over units to steer the car with.
So what happens? Here is how the system works. You the driver stomp down on the brakes and use up 101 units of traction. The computer senses a wheel has stopped moving and it releives brake pressure down to say an 80 unit of traction point. Leaving you 20 units of traction to steer with. Guess what? Your foot is still planted firmly on the brake pedal and quickly raises the brake pressure back up over 100 units and the cycle starts all over. All the time you are requesting more pressure and everytime it stops a wheel, the computer releases pressure from the system. This is the pulsation you feel in the pedal.
If you learn what is known as "threshold braking". The act of braking up to the 99 unit of traction point and holding it there you will have much more stopping power than a system that is constantly releasing pressure down to 80 units on you. It takes practice and a fine touch, but anyone can become very good at it.
We taught this on a skid pad and the stopping distance with "threshold" braking is consistantly 2-3 car lengths shorter than ABS at 20 mph.
The other thing to consider on older ABS systems is that it only takes 1 wheel to stop moving to trigger the release of brake pressure to the WHOLE system. So a heavy corner entry the makes 1 rear tire light can trigger a release of brake pressure to the other 3 wheels that have great traction.
More modern ABS systems now have 4 valve systems that can control each brake individually and do things a driver does not even have the controls to do. Those systems are VERY impressive. The systems in the older cars can do more harm than good to a skilled driver. To a driver that does not know any of this it can be a nice fail safe for their lack of skill.
Ten post był kropką nad i - odpuszczam temat zakładania ABS (czego zresztą bardzo nie chciałem robić) i skupiam się nad znalezieniem miłej kombinacji zacisków...
Autor RE: "To ABS or not to ABS"
pdmobil
Postów: 21
Data rejestracji: 02.06.09
Dodane dnia 04-04-2010 22:52
Uwierz w siebie ! zapowiada się bardzo deszczowe lato smiley ( ja nie mam wyborusmiley)
Dodane dnia 05-04-2010 09:49
nei dziwie sie tej opini na temat starych systemow ABS i nowych. Zawsze znajdzie sie ktos komu on nie podpasuje. Jestem wlasnie po lekturze ksiazki Michaela Cottona ktory opisuje dosc szczegolowo historie wyscigow z udzialem samochodow Porsche tych seryjnych i mocno kreconych. Bylo tez tam pare stronek na temat cyklu Porsche Turbo Cup w ktorym wpierw wszyscy scigali sie bez ABS,nastepnie kiedy bylo juz w opcji wszyscy mieli ABS ale sporo z nich rezygnowala z niego az po jakims czasie nikt sobie nie wyobrazal scigania sie bez ABS....poczytaj lepiej wiecej opini na ten temat bo sugerowanie sie jedna wypowiedzia to troche chyba malo, nie uwazasz?
tkacki
Postów: 372
Dodane dnia 05-04-2010 11:08
Piotr,
To wyjaśnienie dot. ABS jest po prostu... głupie. To jakieś teorie w stylu "na chłopski rozum" nie maja nic wspólnego z teorią działania tego układu. 944/968 bardzo słabo hamuje bez ABS. Sam się o tym przekonałem, gdy miałem zepsutą pompę, Ty zresztą chyba też na Poznaniu. Wadą ABS jest oczywiście hamowanie na powierzchni o słabej przyczepności (piasek na asfalcie, itp) ale to nic w porównaniu z problemami naszych aut z hamowaniem w dobrych warunkach bez ABS. Te auta nie mają niestety właściwych rozwiązań korekcji sił hamowania i bez ABS jest bardzo słabo. "Jakość" kierowcy nie ma tu nic do rzeczy.
CP9A/4G63
We are not what we own.
Dodane dnia 05-04-2010 14:21
Bardzo dobrze że wywiązała się dyskusja - o to chodziło smiley
ABS jest olbrzymim ułatwieniem dla kierowcy - pozwala w odpowiednim momencie po prostu "stanąć" na pedale hamulca i zająć się odpowiednim wpasowaniem w zakręt. W dodatku gdy trochę przestrzelimy hamowanie (ale tylko trochę) pozwala cało wyjść z opresji (możemy zacząć skręcać trzymając jeszcze mocno wciśnięty pedał hamulca). I ma jeszcze jedną podstawową zaletę - oszczędza opony. Czyli teoretycznie wszystkie argumenty są "za".
Ale jazda bez ABS ma coś w sobie. Banalnie jeździ się autem z ABS, ESP, kontrolą trakcji, DSG itp. Szybko możemy zostać "mistrzami kierownicy", osiągać świetne czasy np w Poznaniu będąc nadal kiepskimi kierowcami. Chodzi właśnie o naukę. O poznawanie granic swoich i samochodu. Można kupić np 996 i być o wiele szybszym - ale nie o to chodzi. 944 mają coś w sobie i dają mnóstwo frajdy z jazdy - a wspomniana wyżej elektronika tę przyjemność w dużej mierze zabija. Auto sportowe musi być twarde, głośne, narowiste i dawać wrażenie że zaraz może urwać Ci głowę.
Co do moich kłopotów - rzeczywiście mam problem ze złym balansem. Ale popełniłem szkolny błąd zakładając Brembo bez użycia choćby fabrycznego brake bias valve - standardowego 5/18 czy też opcjonalnego 5/33. W każdym razie problem powinien zostać na dniach naprawiony smiley
huzar105
Postów: 292
Data rejestracji: 19.10.09
Dodane dnia 05-04-2010 19:38
ABS jest dobry im wyższej generacji tym lepiej.
Ja osobiście nie mam 100% czucia auta z absem jednak sądzę, że z tym systemem da radę urwać coś na czasie.
Najlepszy rozwiązaniem jest zrobić wyłącznik i w razie potrzeby załączać system.
Sliwka
Postów: 631
Data rejestracji: 29.07.07
Dodane dnia 05-04-2010 20:00
piterson napisał/a:
Sorry za offtop... Ale masz u mnie piwo przy najbliższej okazji smiley
1543383
huzar105
Postów: 292
Dodane dnia 05-04-2010 20:41
Sliwka napisał/a:
piterson napisał/a:
Ale to chyba nie jest żadna nowość, ani tajemniczość. Można by jeszcze dodać, iż dzisiejsze rajdówki są dużo łagodniejsze niż te 20 lat temu.
Dodane dnia 05-04-2010 21:40
piterson napisał/a:
Musi być widowmakerem, czy wystarczy samo wrażenie? smiley
Co do ABSu to w połowie marca jak znów pojawiły się przymrozki i drogi zaczęły być śliskie, pewien gościu jadący przede mną uznał, że nagle skręci w lewo - chyba miał ABS bo po chwili już stał w miejscu i szykował się do skrętu. Ja dzięki temu, że ford, którym jeżdżę na codzień ma ABS miałem tylko tylni zderzak uszkodzony, gdybym nie miał ABSu kolejne dwa zderzaki byłyby do wymiany. Kierowca jadący za mną, nie korzystał z tego dobrodziejstwa, bo zanim zatrzymał się na moim zderzaku słychać było charakterystyczny dzwięk szorujących opon trących o asfalt...
tkacki
Postów: 372
Dodane dnia 06-04-2010 08:49
piterson napisał/a:
Ale jazda bez ABS ma coś w sobie. Banalnie jeździ się autem z ABS, ESP, kontrolą trakcji, DSG itp. Szybko możemy zostać "mistrzami kierownicy", osiągać świetne czasy np w Poznaniu będąc nadal kiepskimi kierowcami. Chodzi właśnie o naukę. O poznawanie granic swoich i samochodu. Można kupić np 996 i być o wiele szybszym - ale nie o to chodzi..... elektronika tę przyjemność w dużej mierze zabija.
Hmn.... pogadamy na ten temat jak kupisz sobie 997turbo lub coć nowszego.smiley
piterson napisał/a:
Auto sportowe musi być szybkie.smiley
CP9A/4G63
Dodane dnia 06-04-2010 09:03
tkacki napisał/a:
Aż się chce napisać: "straights are for fast cars... corners are for fast drivers" - Colin Mc Rae
Na dzień dzisiejszy najnowszym Porsche jakie chciałbym mieć to byłoby 993 (obojętne czy turbo, GT2 czy RS).
Chociaż w sumie taką GT3 to bym nie pogardził (996 FL lub 997) smiley
Postów: 4257
Dodane dnia 06-04-2010 11:10
piterson napisał/a:
zabrzmiało trochę jak słynne powiedzonko Pana Forda o modelu T - obojętnie jaki kolor, byleby czarny.
Dodane dnia 06-04-2010 11:25
Piotr ja właśnie dlatego lubię stare auta, bo to co się dzieje zależy od Ciebie nie od komputera.
Sam sobie odpowiedz co Ciebie bardziej kręci.
auta z esp, abs, i całą techniką może i są fajne na dojazd do pracy, po bułki do sklepu....
Co do montowania brembo bez zaworu redukcyjnego to istna awaria!!
doświadczył tego browar i nawet z zaworem są sytuacje gdzie tył lekko haczy.
Moim zdaniem w swojej wydmuszce powinieneś mieć zawór na przewodzie idącym na tył w kabinie koło lewarka zmiany biegów.
Często wydmuszki torowe są w ten sposób przerabiane, po to żeby kierowca w zależności od nawierzchni toru mógł dobrać sobie ciśnienie z tyłu. Wtedy zawór z pokrętłem regulacyjnym montuje się w okolicach zmiany biegów i prowadzi przewód hamulcowy przez kabinę.
Sliwka
Postów: 631
Dodane dnia 06-04-2010 18:38
Bluebird napisał/a:
piterson napisał/a:
Jeśli chodzi o zabawkę to może być widowmaker smiley , do normalnego tyrania kilometrów mam Octawię z ABS ESP i sam nie wiem jeszcze z czym... nie lubię jak samochód stara się być mądrzejszy ode mnie, ale mam świadomość że w codziennej jeździe przyzwyczajenie i rutyna gubią, a te systemy jednak potrafią pomóc...
Do porschawki wsiadam dla frajdy i na pewno nie jestem w stanie przewidzieć wszystkiego , ale jeżdżę cały czas ze świadomością że w razie draki samochód mi nie "pomoże" i między innymi dlatego mam taką frajdę smiley .
1543383
hades307
Postów: 1768
Data rejestracji: 02.01.08
Dodane dnia 06-04-2010 21:32
w abs asr i wszystkich innych które mają nowe samochody zawsze nie podobało mi się to że robią coś nad czym nie mam kontroli i że jak to wszystko się powyłącza to mi coś na zegarach się świeci a przy ponownym przekręceniu stacyjki i tak się to wszystko włączy i generalnie samochód z tym wszystkim jest mniej rasowy do prowadzenia a co za tym idzie mniej fajny do zabawy
a teraz tak bardziej poważnie to myślę że abs jest dobry ale musi być odpowiednio dostrojony do wyczynowej jazdy, używając przykładu z pierwszego postu to jeżeli mamy 100 jednostek to nie jest dla nas dobre jeżeli system w momencie poślizgu ujmuje nam 20 i wszystko wraca do normy, ale jeżeli system by dokładnie obliczał jaką maksymalną siłę hamowania możemy użyć aby samochód nadal utrzymywał zadany kierunek jazdy a my byśmy ewentualnie zmniejszali tą siłę aby wykonać jakiś dodatkowy manewr to w takim układzie abs do wyczynowej jazdy jak najbardziej ma sens
zastanawiałem się zawsze jak działał abs w sierrze gdzie była elektryczna pompa i miała 3 obwody prawy i lewy przód oraz tył myślałem kiedyś że on ujmuje siły hamowana w tym obwodzie w którym koło wpadło w poślizg smiley
1978
1979
szukam rocznika '80 smiley
